1991 Accord EX-R Engine Miss
Hi All,
My son picked up his first car recently, a 1991 Honda Accord EX-R that needed and needs a lot of work.
1) Drivers door latch-now fixed
2) Muffler & tailpipe assembly-now fixed
3) Heater fan blower motor-replaced but very little air comes out the vents or defrosts. I’ll have to go back in and see what I did wrong.
He took the car to work for its maiden voyage yesterday and when he got home there was a miss in the number three cylinder. I pulled the lead wires off each cylinder while the engine was idling and the 3rd cylinder is the only one that didn’t make a difference.
I removed all 4 plugs expecting to see the #3 wet and fouled but it looked just like the others, dry as if it was firing. I did a “hot engine” compression test and all 4 cylinders are at 190 psi.
I’m wondering if anyone can tell me why the plug in the #3 cylinder would not be wet if it wasn’t fireing?
Thanks for any and all feedback!
Never mind, I think I located the problem with the # 3 cylinder miss. I pulled off the distributer cap and found a large pool of motor oil sitting at the bottom shorting out the #3 rotor cap contact. Now I’m wondering how the oil got into the distributor cap? I will do a quick site search and see if others have had this issue in the past. Thanks.
If there is oil inside the distributor it will be the inner seal not the outer o-ring that is the issue. This seal can be replaced, however there is no Honda part number. You will probably have to buy it from a seal or bearing parts store or from an online source. The part number is NOK BH3888E.
There is a pretty good DIY here on H-T. If you do a search for distributor inner seal it should come up.
I ordered the seal and O-ring kit off eBay late last night and got conformation that it shipped this morning. Total for both pieces including 9 bucks for shipping to Western Canada was $18.93 US.
CEL2018
Oct 4, 2018 07:56 AM
HeresOtis
Nov 10, 2017 01:21 PM
