OBD1 conversion woes
Old Jan 6, 2013 | 07:47 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default OBD1 conversion woes
i cannot get the OBD1 conversion running well. the engine is a stock (functionally) D16A6, with a non-VTEC OBD1 distributor (TD41U) with OBD1 conversion harnesses on a P06 ECU that is running Neptune Demon.
i have been getting CKP code sporadically and seemingly at high RPM/load only. lately, the ECU went into limp mode after a full throttle stint without a code.
i also do not have a proper O2 reading (i am using the stock one wire sensor). i have replaced the distributor with no effect.
Old Jan 6, 2013 | 10:11 PM
First.EG's Avatar
Default Re: OBD1 conversion woes
I would try A stock ecu first before anything else.
Old Jan 6, 2013 | 10:33 PM
i haven't gotten a stock ECU, and even a stock ECU would not work for me, the engine is an OBD0 engine.
Old Jan 7, 2013 | 01:35 AM
ef92b's Avatar
any chance you're using non OEM spark plug wires?
might be the issue. try using an OEM set.
Old Jan 7, 2013 | 01:55 AM
why would the plug wires be the culprit all of the sudden? they performed well for all these years in the OBD0 configuration.
Old Jan 7, 2013 | 02:31 AM
ef92b's Avatar
they might be leaking and can cause EMI/RFI to the ECU.
had experienced it twice and sure it drove me nuts trying to find the fault/s.
Old Jan 7, 2013 | 05:35 AM
HondaPartsHero's Avatar
Technical Hero
Test the CKP just to eliminate any variables
Old Jan 7, 2013 | 09:43 AM
i have done it already, but will do again, with the new distributor, will report the results.
Old Jan 7, 2013 | 12:17 PM
hybridmiklo's Avatar
is the ecu looking for an o2 sensor reading?
Old Jan 7, 2013 | 03:46 PM
I have kept the O2 sensor enabled, as I have connected my stock one to it. It is most likely a ground issue with that, but I am not as concerned about that as I am about the ckp code and now a mysterious limp mode.
Old Jan 7, 2013 | 08:24 PM
i'll wrap the distributor OBD0-OBD1 harness in some foil to see if that helps.
Old Jan 8, 2013 | 08:13 AM
Technical Hero
Are you using a dizzy adapter? If so you may want to resistance check your adapter. Same thing with the CKP wiring at your ecu adapter, but like earlier said might be good if you could check a stock ECU if you have access.
Old Jan 8, 2013 | 11:52 AM
Technical Hero
Also this could be random but I'm not sure what brand harness you are using
http://hondaville.com/honda/threads/...-mode-RESOLVED
Old Jan 8, 2013 | 01:26 PM
I think you might have nailed it. Using cheap ebay adapters. (Wires and molex connectors are just wires and connectors, right?)
I will need to check the integrity of that harness.
Old Jan 8, 2013 | 03:10 PM
it was indeed the CKP/O2 wiring on the harness. the CKP and O2 wires off the OBD0 plug both went to the CKP pin on the OBD1 plug. i snipped and spliced the O2 wire to its correct location on the OBD1 plug and the system is operating nominal now.
Old Jan 9, 2013 | 03:19 PM
Technical Hero
THUMBS UP!!
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
MniMeHatch89
May 24, 2007 09:10 PM
tRex99
Sep 5, 2004 05:28 PM
