B18 swap in a 88 crx si-shift linkage question
Old Jan 6, 2013 | 03:29 PM
Chris2001991's Avatar
Default B18 swap in a 88 crx si-shift linkage question
Hi Honda tech!!.i have a b18 swap in my 1988 crx si..the question I want to ask is how do u connect the shift linkage to the tranny?..I'm new at this and I honestly don't know how to do it..all help will be much appreciated..thanks!!..
Old Jan 6, 2013 | 04:10 PM
F22Master's Avatar
Default Re: B18 swap in a 88 crx si-shift linkage question
Bitch pin. Google it
Old Jan 6, 2013 | 04:42 PM
zrickety's Avatar
Do you have the B18 linkage? It will need to be cut down and welded to fit, or you'll need pre-made swap linkage from someone like Hasport.
Old Jan 6, 2013 | 04:43 PM
Yea i have a b series crx si shift linkage
Old Jan 7, 2013 | 12:31 PM
It lines up with the tranny..I have it connected as we speak..but on the othe other end were the shifter is it won't go through the hole..any ideas why?..I looked it up and asked a couple friends and they said to get a b series crx shift linkage..so I did and it doesn't fit?..is that the right one?..do I have to put it in a certain way?
Old Jan 7, 2013 | 12:52 PM
F22Master's Avatar
How doesnt it fit?
Does the shifter line up with the hole?
Will it not go in all the way?
Here is what the correct linkage looks like:
http://hasport.com/store/index.php/a...e/efblink.html
Old Jan 7, 2013 | 01:34 PM
No..it doesn't line up..I don't get why..does it go in a certain way?
Old Jan 7, 2013 | 01:51 PM
F22Master's Avatar
When I did mine i bolted it in the car, then attached it to the transmission.
Old Jan 7, 2013 | 02:18 PM
maddix's Avatar
make a photo of yours.
Here is mine:
https://honda-tech.com/forums/showpo...0&postcount=10
may be you should short them, like i did?
unabonger
14
Jul 1, 2020 03:34 AM
VtecNotRequired
Apr 15, 2012 11:55 AM
streetsold6teeny8
18
Jun 29, 2009 10:18 PM
EFM_ookie
Jun 20, 2007 09:31 AM
thecorey
Oct 21, 2002 11:01 PM
