NEED HELP - HARNESS ISSUE - 94 GSR
I want to see if anyone can help me out with an issue - the previous owner of my 94 GSR chopped on the ECU end of the harness, now im having a hard time getting Hondata to communicate (amongst other things).
there are 3 wires, what i think may be ground wires - coming from the following: one coming from the D3 red/blue wire, one coming from the D14 white/red wire, and one coming from the cluster of wires that are B11 thru B16.
i've attached pics below - if anyone has an idea what these silver looking uninsulated wires are that are routed along with the abovementioned wires, or what they should be connected to, please let me know! (they are wrapped in elec tape right now, if you need better pics i'll post more)
thanks for any help that you can offer!
Red/blue is knock sensor.
White/red is to heated O2 sensor.
You did not give a color for the one coming out of the "cluster of wires".
The, "silver looking uninsulated wires" is shielding for the wire/wires it is around, it is grounded to chassis 94
ok, i should have been more specific in saying that i needed to know what the uninsulated wires were for... actually they are not grounded right now so i'll take care of that. thanks for the help
