1998 Honda Accord V6 Oil Leak, Unknown Bolt
Old Jan 6, 2013 | 07:39 AM
Torino117's Avatar
Default 1998 Honda Accord V6 Oil Leak, Unknown Bolt
Hey there I recently discovered an oil leak on my Accord, it's a 3.0 V6.
The only area that was slightly wet with oil was the corner of my oil pan along with some oil pan bolts, I thought it was the drain bolt, with a little snooping I believe I may of found a bolt that it's coming from, as it appears to be dry in the area above that bolt.
Here are some pics, yellow oil filter on right, axle on left, and row of bolts on bottom is the top of the oil pan, this bolt is the larger one just above.......if anyone can tell me what it is that'd be great.
Old Jan 6, 2013 | 10:10 AM
jdowen2's Avatar
Default Re: 1998 Honda Accord V6 Oil Leak, Unknown Bolt
Oil pressure switch sits above that. Check that first. I think the bolt mounted 90 degrees to block is bearing cap side bolt.
Old Jan 13, 2013 | 05:38 AM
Torino117's Avatar
Checked the sensor it's good and dry. Thanks though, I'm not sure if it's coming from that bolt or the thread plug above it..
Old Apr 17, 2014 | 09:19 AM
Kamil250's Avatar
Did you ever figure out what was leaking? I have the same issue.
Old Oct 18, 2014 | 07:31 AM
Rifleman's Avatar
I have the same issue also. What is the plug above the oil Plug?
boostmee
Aug 18, 2008 02:05 PM
paawk2000
Jul 16, 2007 07:54 PM
ombl4
May 10, 2007 01:42 PM
teewhy55
13
Dec 13, 2004 11:17 AM
eg crunkmonster
Feb 3, 2004 08:47 PM
