turbo D help
Old Jan 6, 2013 | 12:33 AM
97ej8_mitch's Avatar
Icon6 turbo D help
im wanting to build a turbo d series a d16y8 and my prob is that I have a p2p ecu obd2 should I swap the engine and main harness out for a dif d series or do a ecu conversion jumper set up what the good and the bad is it a good idea to us a jumper or does it have the potential to make bacon out of my wires?
Old Jan 6, 2013 | 12:48 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: turbo D help
OBD2 to OBD1 sub harness, OBD1 ECU with modification. OBD2 to OBD1 distributor sub harness.
Old Jan 6, 2013 | 04:56 AM
grumblemarc's Avatar
The Grumpiest
You have a lot of reading to do.
Old Jan 10, 2013 | 10:07 AM
9hatchturbo5's Avatar
Old Jan 11, 2013 | 12:42 AM
crxsi1's Avatar
Hey I'm havin trouble finding a procedure on a 14b turbo setup on a d15b8, if you could point me in the right direction that would great. So far I have a d15b8, ex/ si tranny, dsm rebuilt 14b and exh mani w injectors. Still deciding on head, either z6 or y8 I'm thinking... Motor only has 135k and is well taken care of... Only looking to run around 8psi so what ever you can input on would be great....
Old Jan 11, 2013 | 12:45 AM
wantboost's Avatar
Who is Mr Robot?
Make a new thread....
And i have a y8 head :D lol
Old Jan 11, 2013 | 03:00 AM
The Grumpiest
Finding a procedure? WTF does that mean?
Old Jan 11, 2013 | 10:10 AM
crxsi1's Avatar
Well for some reason I can't start a thread, it won't let me... So sry for kinda jumpin on this one. But what I'm sayin is I'm looking for procedures on the 14b setup, where exactly to tap oil lines, wireing, ect... I plan on doing this myself...
Old Jan 11, 2013 | 10:59 AM
mitsuman's Avatar
you guys will have better luck on d-series.org
Old Jan 11, 2013 | 11:19 AM
wantboost's Avatar
Who is Mr Robot?
And the 2nd guy will have better luck paying a shop
Old Jan 11, 2013 | 03:22 PM
crxsi1's Avatar
I will check d-series.org, thanks... I was thinkin about just bringing over to a local shop but I really don't want to pay someone... I've never done this before but have rebuilt motors from the ground up on several occasions and have messed w my friends dsm's, so a little experience with turbo's... So will see, most likely do majority of work and have the shop do the more detailed work... But thanks for the advice...
jzavala
17
Nov 24, 2015 04:56 PM
Aquafina
Jun 8, 2007 02:18 PM
THC07
Oct 2, 2005 10:00 PM
Schaz
May 16, 2005 11:46 PM
