98 accord 4 cyl. auto trans grinding noise
Old Jan 5, 2013 | 05:32 PM
a32e5s7's Avatar
Icon2 98 accord 4 cyl. auto trans grinding noise
Hey guys, I have a 98 accord that developed a problem. When not in gear, there is a grinding noise (like metal against metal type of a grind) from the transmission. It's definitely coming from the transmission, took it to a Honda dealer to confirm.
Another issue is that most of the times the torque converter wont lock up either, unless I drive the car like crazy for a while (redlining), then all things are normal, except for the grinding noise when not in gear.
Any ideas whats going on?
Car has 196k miles and the last time the tranny got new fluid was around 170k, but not at Honda at Jiffy lube
Old Jan 7, 2013 | 05:55 AM
a32e5s7's Avatar
Default Re: 98 accord 4 cyl. auto trans grinding noise
Anyone have any ideas or at least point me in the right direction?
Old Jan 9, 2013 | 05:33 AM
a32e5s7's Avatar
Looks like I've read plenty of information online, including here, to know that this is a very common problem. I am going to go to a Honda dealer tonight where my friend works and we're going to do a full trans flush...BTW, Honda doesn't use power flush, they have 2 big tubes, one with new ATF and one is empty. The torque converter does the pumping.
I'll also find out what ATF fluid they actually use, they obviously buy it from somewhere since Honda doesn't manufacture oil.
Even though no one replied, I'll keep this thread going to provide additional info to those who may have the same issues.
Old Jan 9, 2013 | 06:40 AM
gdrew888's Avatar
Sorry but I don't have any answers for your question. Thanks for keeping us informed regarding Honda tranny fluid. I will be doing a drain and refill of my son's 91 Accord auto trans this week. I picked up three litres of fluid and a crush washer from the dealer yesterday and they gouged me $36.71.
Old Jan 9, 2013 | 09:01 PM
a32e5s7's Avatar
As I was expecting, changing the fluid didn't do anything for the noise. It does shift smoother and feels like it actually accelerates faster, not sure if that's just the feeling, but I am pretty sure it does. But the noise nevertheless is still there. Looks like my tranny is about to bite the dust.
Old Jan 9, 2013 | 09:05 PM
a32e5s7's Avatar
Does anyone know if the older accord tranny's were better than Gen 6? I know that those trannys will fit, although I am not sure what all needs to be done to make it work. Or perhaps an H22 one will work better.
Old Jan 10, 2013 | 01:13 PM
MAD_MIKE's Avatar
MM Gruppe B
98-02 4spd ATs have known issues, overheating TCs and the like, mostly due to insufficient flow from the PR valve, this will cause no flow through the cooler and cause the transmission to overheat. The problem occurs below ~1200rpm. Have your buddy check for correct pressure and flow through the cooler.
90-97 Transmissions are not interchangeable with the 98-02 cars. 98-02 are fully computer controlled.
Old Jan 12, 2013 | 07:58 PM
a32e5s7's Avatar
I am assuming that it may be too late now to do anything other than to drive it till it dies or replace right away, or could fixing the PR valve fix the problem?
Old Jan 12, 2013 | 08:30 PM
f1drivr's Avatar
Sounds like you have some needle bearings going or gone out. So the more you drive it the more damage is being done. If your hearing grinding noises there not going to get any better.
Old Jan 13, 2013 | 07:44 PM
MAD_MIKE's Avatar
MM Gruppe B
If after testing there is lack of flow through the cooler, it is most likely the PR valve is over correcting and blocking flow. Sonnax sells a fix for this. However, the problem with Honda ATs is the only way to access the PR valve, which is in the valve body, is to remove the transmission and disassemble it. It is not like conventional ATs where the valve body is readily accessible via a pan.
Old Jan 13, 2013 | 08:05 PM
a32e5s7's Avatar
I'll have the flow tested this week hopefully. But my question is this, regardless of the findings, isn't it too late for the fix since the transmission is making that grinding sound?
Old Jan 14, 2013 | 12:11 AM
MAD_MIKE's Avatar
MM Gruppe B
The goober thing about Honda ATs is they are not end user friendly. Anything outside of a shift solenoid change or fluid replacement requires the transmission to be pulled.
Dimas Thor
Apr 23, 2016 10:11 PM
shortyroc24
Sep 27, 2011 08:16 PM
z28miket
Oct 28, 2010 01:51 AM
brownje000
Aug 17, 2008 02:41 PM
fuckintuckin
May 23, 2005 11:41 PM
