Can't maintain cold idle at all
Old Jan 5, 2013 | 02:04 PM
pentaq's Avatar
Default Can't maintain cold idle at all
The patient: Accord Wagon H22 boosted- Euro R intake manifold and modified TB with idle setting screw.
IACV relocated to the firewall using Rosko stuff.
Neptune RTP on board- tuned.
When starting the car I have to keep TB opened a bit for a while. When the car gets some temperature it keeps 1000rpms as set. But braking or full turning chokes the engine and causes stall. If I don't it dies in sec. The engine never tried to reach up to 1600 rpms as set in Neptune.
Replaced two IACVs- no change.
I checked if IACV got +12V and ground when running on proper pins- they're OK.
Checked also if IACV clicked when got power and ground directly from the battery- OK.
Below idle settings:
What should I check more? Any ideas?
Thanks
Tom
Old Jan 5, 2013 | 02:53 PM
torkh22a's Avatar
Default Re: Can't maintain cold idle at all
this occur when it gets up to temp also? what does your fuel trim look like vs ect?
Old Jan 5, 2013 | 03:34 PM
93supercoupe's Avatar
turn your target idle way up and see if it tries to match it when warm.
Sounds like the IAC is bad tho.
Old Jan 6, 2013 | 01:23 AM
pentaq's Avatar
When hot (even half-hot) the engine keeps set idle. Doesn't bounce.
Fuel vs ECT below:
jdm_prelude19
Apr 4, 2011 05:58 PM
cfoland
Feb 18, 2011 07:57 PM
JasonST
Jun 30, 2006 11:22 AM
Brian_92GSR
May 31, 2004 03:57 PM
steve_s
Jan 22, 2003 02:06 AM
