EP3 Transmission Help
Old Jan 3, 2013 | 04:13 PM
Joepiper151's Avatar
Default EP3 Transmission Help
Whats up guys, So over the past week i've been helping my brother replace a clutch in his 03 Civic Si. Everything seemed to go smooth other than bleeding the clutch because of the location. the bleeder screw is under the intake manifold which makes it a massive pain in the ***. anyways. I felt like i got pressure in the pedal, so we drove the car up the road.
it seemed to be fine but at the top of the road there was a small pop and then it would not move, it felt like it was in neutral. It feels like it goes into gear but nothing happens. any ideas where to start troubleshooting.
Thanks Guys, any help is appreciated
Old Jan 3, 2013 | 06:45 PM
lazlong's Avatar
Default Re: EP3 Transmission Help
Does it feel like it's in neutral (some resistance) or like the linkage/shifter is broken (no resistance)?
Look for leaks and try bleeding the system again. If that doesn't work you may have a bad master or slave cylinder or, you may have to pop it back open to see what happened.
Old Jan 4, 2013 | 09:53 AM
scmil95eg's Avatar
pop the axle back in.
Old Jan 4, 2013 | 08:03 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Just curious as to why you bled the clutch line after a clutch instal? Did you open the system accidently?
Anyways if you put the car in gear when it's off and then turn it on still in gear what happens?
be4unvme
Jan 1, 2014 06:22 PM
MTracing
Transmission & Drivetrain
Jan 10, 2012 11:27 AM
2wheelhunter
Aug 30, 2006 07:56 PM
mdj_ge
Dec 3, 2004 06:45 AM
ls95hatch
May 24, 2003 09:34 PM
