direct fit b18b parts
Old Jan 3, 2013 | 02:14 PM
97teggyb18b's Avatar
Icon2 direct fit b18b parts
I have a 97 Integra with a b18b Jdm motor. I have worked on a b18b1 before but the B18b has some differences from what I can tell..... My question is, Does anyone know what parts are interchangeable between the two? It does say B18B on block with no number after. It did come from japan. and it has about 57k on it. Im sure this question has been asked before... but to learn more about it I thought I would ask. Just hoping I can pull parts off of a B18b1 if something goes bad.
Old Jan 3, 2013 | 03:04 PM
B20ztek's Avatar
Default Re: direct fit b18b parts
Everything is interchangeable, their just about the same.
Old Jan 3, 2013 | 03:08 PM
I know one difference is the compression I believe its 9.2:1 in the b18b
That makes me think there is more.
Old Jan 3, 2013 | 07:54 PM
dc2LS's Avatar
Everything is interchangable as stated above.
Old Jan 4, 2013 | 02:30 AM
Eg.ls.turbo's Avatar
B18b and b18b1 are same the same motor only difference is the jdm b18b has a higher compression 9.4cr and the usdm b18b1 is 9.2cr. So the jdm piston has a .2 higher compression
kwade9015
Apr 4, 2016 10:27 AM
