problem with swap
Old Jan 2, 2013 | 11:07 PM
jarhead90crx's Avatar
Default problem with swap
I put new rod bearings in a B16 and swapped it into my 90 crx si. I put assembly lube on both sides of the bearings and the crank would spin very easily. Converted it to OBD1, using a chipped p28, gsr cams.
Problem is the engine cranks but the cam gears and timing belt are barely turning and the car won't start.
Any ideas?
Old Jan 2, 2013 | 11:53 PM
DCRB's Avatar
Default Re: problem with swap
video?
Old Jan 3, 2013 | 02:30 AM
Won't be able to post video til either tomorrow or friday, the car is at a friends house
Old Jan 3, 2013 | 05:49 AM
mtflyboy25's Avatar
um... when you crank it, they usually look like the turn slowly... Maybe you mean really slow. Is the timing belt on tight/correctly?
Old Jan 3, 2013 | 06:28 PM
DignityStyle29's Avatar
Did you torque the cam shafts down too tight?
EdwinCheng
May 7, 2014 01:28 PM
jdmboy94
Apr 10, 2009 12:40 PM
90jdmcrxdude
May 17, 2006 09:39 AM
lilxvtecxpwr
Dec 25, 2002 12:21 AM
