91 Civic B18B1 Code 9..Running Rich&Starting Problem ..HELP
Whats up Honda-tech I have a 1991 Civic Hatch Back....B18B1 Swap...OBD1 Intake Manifold/OBD0 Guts...OBD0 Ecu,OBD0 Distributor..
I bought car with Blown Motor Ripped Out....Wiring Harness Was Hacked...Injectors Were Wired Wrong He Cut Whole Main RelayPlug off And Rewired Wierd.
So I Fixed Harness/Fixed all Broken wires/Plugs..And fixed Reversed Wire's/Put Swap In And Got it Running and Runs Great And Motor Sounds Smooth....
But I have a CODE 9 CEL CYP Sensor...(Which One Would i Replace All 3 Or one of Bottom Sensor in Dizzy
And im Having a Problem With Car Not Cranking/Clicking Wont Start After Setting For 20 Mins or So...I Figured It Was a Bad Ground..So i Resanded All 4 Engine Bay Grounds..Made Sure they Have Good Connection...
I Checked...Alt Fuse,Starter Signal Fuse,ECU Fuse,Battery &IGN Fuses...All Good
I Changed Starter & Not the Problem
And Battery is Fully Charged Its Not Dead When its Doing this Either...
I thought it was my Battery in Trunk So i Put it Up Front With 2 Grounds to It..&A 6 Gauge Alt Wiring to Battery
I Changed Main Relay Not Prob
My Door Signal on Cluster Blinks &Sounding Like Clickin or Unlock/Lock (Dunno if this would be a Sign or Sumthin
I Changed Ecu..
If i Push Start it And Have it running for 10+ Mins and shut off....it will fire right up..
Main Relay Does Click When im Holding to Key to try to Start When it Wont Do Nothing.
i Made Sure Starter Signal Wire is On Also
The Car Acts Like I Took Starter Signal Wire off...Because It Dont Do Nothing...But I Even Have Someone wigglin Signal Wire Also
Could it Be that Something isnt Wired on Main Relay Right?
BUT PLEASE HELP ME I CANT FIGURE THESE 2 PROBLEMS OUT...
Sry Bout Long Post But i wanted to Cover all Base's So if u guys had same problem u can pass on Word
I Changed Ecu..
Make sure the two wires of the CYP sensor (inside distributor) are properly pinned to the ECU.
http://www.phearable.net/tech/wiring...schematics.gif
I tested connections to ecu and distributor...and ecu got power...the sensor is dead..can i use obd1 b18 CYP/TDC Sensors ina obd0 dizzy if i convert dizzy plugs?
Mr.Galloway
Jan 16, 2015 06:45 PM
91SOHCSI
Jul 26, 2008 08:50 AM
Butch
Feb 23, 2004 06:44 PM
WhiteDSM520
May 6, 2003 11:06 PM
