OBD-1 Dizzy Into a B20B
My 1991 Civic wagon has been converted to OBD-1.
Will a OBD-1 Distributor off a ls integra fit my OBD-2 B20B. I was planning on buying the Rywire OBD-1 Wiring harness. So can I just get a OBD-1 Distributor for my B20B, and the Rywire OBD-1 plug should just plug right in?
Same goes for the alternator, injectors, etc? Everything has to stay OBD-1 if my car is wired for OBD-1 right?
distributors can be used between any motor b-series as long as the mounting is the same.vtec vs nonvtec.if your using the dist on the b20 which is obd2 just buy a dist jumper to convert it to obd1 which is what your car is.
Thanks. Thing is when I bought my B20b from the JDM store in was just the head and block no external parts. So basically I was most likely going to go to the junkyard and get the parts. Would it be best to just stick with OBD-1 parts? Since everything should be just straight plug and play right?
