del sol radiator fan not working
Old Dec 31, 2012 | 02:58 PM
woahdelsol's Avatar
Icon2 del sol radiator fan not working
i have done some research and havent found anything that has helped.
i had a 93 del sol si, i swapped the motor to a new shell. everything worked fine in my old shell. when i swapped the engine over the fan does not kick on. i replaced the fan switch and thermostat, also checked the fuses.
fan will kick on if the circuit is looped. but why will they not kick on by themselves?
what else could be the problem?
any help would be great!
thanks in advance.
Old Dec 31, 2012 | 04:06 PM
TPB's Avatar
TPB
Default Re: del sol radiator fan not working
fan relay?
Old Dec 31, 2012 | 06:16 PM
woahdelsol's Avatar
i feel dumb, wheres that located? fuse box under hood? checked those they were all fine.
Old Dec 31, 2012 | 06:18 PM
Fliptard's Avatar
car not getting warm enough to kick on?
Old Dec 31, 2012 | 06:25 PM
woahdelsol's Avatar
no, car overheated. when i looped the fan, it did stay much cooler.
should i just wire it to a switch? i was also planning on putting water temp and oil pressure gauges in.
Kush2Slow
Mar 8, 2014 05:52 PM
94_DEL_SOL_VTEC
Dec 9, 2013 01:12 PM
KYDelSol
May 31, 2012 02:15 PM
Michael Thomas
11
May 2, 2012 09:08 AM
lilsol89
Aug 22, 2008 02:43 PM
