Cluster issues again!!! help!
Old Dec 29, 2012 | 04:41 PM
TomCurllyFry's Avatar
Default Cluster issues again!!! help!
whats up guys so i have had mutiple post about this topic from what i thought was fixed started again heres a video so you get an idea and if theres any solutions or even a wiring diagram im too the point where i just wanna re-wire the whole danm thing just waiting cus im not sure if its a wires or cluster issue
Old Dec 29, 2012 | 05:05 PM
Default Re: Cluster issues again!!! help!
http://www.youtube.com/watch?v=64e2E...ature=youtu.be
Old Dec 30, 2012 | 01:43 AM
Built4Battle's Avatar
take off the clear plastic then carefully take out the needles.hold the black part and pull straight or pry it gently with small flat head.drive next to someone doing 45mph for example and stick the needle back in. rpm put it around 800-1000.
I had the same problem couple years ago when i took apart my cluster to paint the needles and other things
Old Dec 30, 2012 | 01:44 AM
oops sorry. didnt read the description in your video
Old Dec 30, 2012 | 04:41 PM
fcm's Avatar
fcm
Old Fart
I'm guessing cold solder connection on the circuit board for the speedo, maybe a ground.
What is the MM&Y of the car?94
Old Dec 31, 2012 | 10:01 PM
its a 94 CX hatch stick shift
Old Jan 1, 2013 | 11:14 AM
fcm's Avatar
fcm
Old Fart
If tapping the cluster gets it to work, then as mentioned it may just be a cold solder connection or a poor connection at a plug pin, or maybe the connections of the speedo to the rest of the cluster, pull the cluster and check all connections. 94
burnykawizzle
Apr 27, 2010 07:55 AM
thisboyjulio
Sep 5, 2007 05:42 PM
1991hb
Feb 8, 2007 04:38 AM
Double_Dk
Jun 10, 2004 05:32 PM
