compression test results......not good
Old Oct 19, 2002 | 09:17 PM
dirtySOHC's's Avatar
Default compression test results......not good
so today i was messing around with my nitrous set up and i took my car for a test run. car pulled hard....harder than ever. when i came home to check my plugs i found the the number 3 plug was melted. this then led me to a compression test. everything checked out. 170 165 165 170. so tonite i am coming home from a friends and i see i am starting to over heat. im like god damnit! lift the hood and my overflow tank is about to OVERFLOW. i rechecked my compression and i came up with this. 155 150 165 170....number 3 and 4 dropped. so now i am thinkin wat could be wrong? since i was oveer heating i am thinkin head gasket. but since i had a melted plug earlier im thinkin rings or hole in the piston.....or burnt valves.
tomorrow i will do a leak down and see wats up. could you guys think of anything. would it be alright to drive my car around like this until i can pin point the problem. and one more thing when i was doing the compression test i noticed a bubbling noise coming from under the intake manifold.......??? wat do you think?
please help me out.....this is my only ride.
Old Oct 19, 2002 | 09:49 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: compression test results......not good (dirtySOHC's)
minor piston damage + blown headgasket.
So what nitrous setup and tune where you running?
[Modified by Mista Bone, 1:49 AM 10/20/2002]
Old Oct 19, 2002 | 10:23 PM
Default Re: compression test results......not good (Mista Bone)
NOS wet jetted at 50. i think the bottle pressure was too high.....i dont have a guage so i couldnt tell......
if i had minor damage to the pistons would this be safe for me to drive for a while......you think maybe i can replace the gasket and just run with it for a while.....
Old Oct 19, 2002 | 10:55 PM
Mista Bone's Avatar
D Tranny Guru
search "Redneck Rebuild" then reask the question.
Noitce I said MINOR piston damage.
Old Oct 20, 2002 | 04:32 AM
bump
Old Oct 20, 2002 | 05:53 AM
so i looked it up but i am not quite following. are you saying cuz after the rebuild your #3 cylinder comp was 165 and by that you are saying i can just change out my gasket and run fine?
Old Oct 20, 2002 | 07:01 AM
Chiovnidca's Avatar
Old Oct 20, 2002 | 09:11 AM
Default Re: compression test results......not good (Chiovnidca)
last night i ran a few more comp tests just to make sure. i read 160 160 160 165. they are pretty low but minimum comp listed is 134. hopefully the damage is not as bad as i think it is. if its just the head gasket i will be more than happy. i cant do the leak down till i am off of work and even then i dont know if i will have time to do it...
*nate who hates obligations when his car is in need*
Old Oct 20, 2002 | 03:43 PM
3rdGteg's Avatar
yeah it's prolly just the head gasket...
Old Oct 20, 2002 | 06:39 PM
Default Re: compression test results......not good (3rdGteg)
here are some pics of my plugs after running the car today. only from work and back......less than 4 miles. they dont too good to me. wat do you guys think....?? sorry they are kinda big..
Old Oct 20, 2002 | 08:11 PM
3rdGteg's Avatar
Yeah, u looking like you're running real hot up in that combustion chamber; you better ease up on that bottle and take a look at your pistons when you pull your head off to do a head gasket. I'd get that leakdown test done before anything though.
Old Oct 21, 2002 | 05:53 AM
MikeSarr_GSR's Avatar
that looks like a lean condition, definately get the sucker checked out
Old Oct 21, 2002 | 07:21 AM
will do.....i sold my kit the same day this **** happened......im done with nitrous.
[Modified by dirtySOHC's, 4:21 PM 10/21/2002]
[Modified by dirtySOHC's, 2:28 AM 10/23/2002]
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
94_civic_tuner
Oct 10, 2007 02:00 PM
integraRS-T
Jul 3, 2007 12:37 PM
racingant
Dec 6, 2005 08:03 AM
