DSM 450cc's in a pre obd integra?
Old Oct 19, 2002 | 09:14 PM
wrXtian's Avatar
Default DSM 450cc's in a pre obd integra?
i'm lookin into trying to get some dsm injectors for my integra.. just curious how u get these to work? and do they plug right in? i know some pple have problems with obd 1 and obd 2.. should i expect anything from a pre obd?
Old Oct 19, 2002 | 09:33 PM
sutrusu's Avatar
Default Re: DSM 450cc's in a pre obd integra? (xjdm94x)
dealing with the afc hack (which i'm guessing is what you're talking about) people have problems with obd0 because there are 2 o2 sensors.. obd1 is easiest to work with.
[Modified by sutrusu, 6:34 AM 10/20/2002]
Old Oct 19, 2002 | 10:22 PM
Sonny's Avatar
Default Re: DSM 450cc's in a pre obd integra? (sutrusu)
The pre-OBD aka OBD0 (86-91) Integras do not have 2 O2 sensors. The first gen B16A does.
Sonny
Old Oct 19, 2002 | 10:55 PM
wrXtian's Avatar
Default Re: DSM 450cc's in a pre obd integra? (Sonny)
yeah i have a single wire o2 w/ only one o2 sensor.. my plan is to get the dsm 450 cc injectors, run a smaller disk in my fmu, and continue to use my inline fuel pump. i basically just want to know what it will take to get these injectors in and what it takes to get them to work.
thanks
Old Oct 20, 2002 | 01:48 AM
Sonny's Avatar
Do you have the B18A1 or the D16A1?
Regardless, your clips will work with the DSM injectors just fine.
I have not tried the DSM injector in either of the above 2 fuel rails, but I know that it will work fine in most B series rails. I plan on running them in my D16A1 fuel rail, but I currently don't have a set of DSM450's to test fit.
Sonny
salman
May 10, 2006 10:55 AM
Haberdasher
Nov 25, 2003 08:33 PM
turbo95coupe
Dec 2, 2002 12:43 PM
threatcon13
Jan 31, 2002 08:32 AM
