break light not working please help!
Old Dec 28, 2012 | 06:32 PM
jdmhondas4life's Avatar
Default break light not working please help!
hi i have a 2000 civic si and im having problems with my break lights they dont get brighter wen i press the brake pedal and i keep getting pulled over.... i changed my bulbs, the brake light switch and the fuse but they still dont work... here is were im getting confused all the 7443 bulbs are 13.5 volts but are suppose to work with 12v systems??? my car is putting a steady 12.7 volts were the bulbs are inserted what can be wrong ??? i did check my ground and also the switch is working fine... can some one give me some feed back please!!
Old Dec 28, 2012 | 08:03 PM
Burningrambo's Avatar
Default Re: break light not working please help!
Check the harness for corrosion. Normally(the corrosion that is) would be a greenish color. Check inside the bulb insert also.
Old Dec 29, 2012 | 06:13 PM
rickkane's Avatar
That is a dual filament bulb you're using right? Did you have someone test the sockets when you apply the brake? Did you check the connection at the brake switch? There aren't too many things that can be wrong. It's either the switch, bulbs, sockets or wiring. Start eliminating things.
atto
Feb 14, 2011 09:33 AM
mackoy20
Dec 17, 2006 06:01 AM
vinny76010
Apr 20, 2006 12:32 PM
CIVIX
11
Feb 27, 2003 03:51 PM
REDBARON
Aug 27, 2002 06:54 PM
