Hardcore stuck ball joints/wheel bearing
Old Dec 27, 2012 | 08:05 PM
NZXTInerTia's Avatar
Default Hardcore stuck ball joints/wheel bearing
After completing my 5spd swap today on my 94 Accord I was double checking the lugs for tight-ness and I snapped a damn wheel stud. When I did my swap I removed the upper/lower control arms and the knuckle all as one piece due to a STUBBORN *** upper and lower ball joint that just refuse to come loose.
I have heated the knuckle up with a propane torch, let PB blaster sit on it for days. Yes I have a pickle fork, yes I have used it, and yes it has honestly bent trying to get these things out.
Suggestions?
On top of that I need to remove my wheel bearing (and preferably not replace it ) to get my new wheel studs in.
Someone please give me some help, I need my car 100% by Wednesday.
Old Dec 27, 2012 | 08:26 PM
holmesnmanny's Avatar
Default Re: Hardcore stuck ball joints/wheel bearing
http://www.harborfreight.com/tie-rod...ller-1752.html
This is all you need to separate ball joints and tie-rod ends.
Old Dec 27, 2012 | 08:45 PM
Any suggestions on getting the wheel bearing assembly out without damaging it?
Old Dec 27, 2012 | 08:53 PM
There are how-to's just search for "rotor replacement" or stuff like that.
Old Dec 27, 2012 | 08:56 PM
btw it's not really wheel bearing assembly it's going to be hub assembly.
Old Dec 27, 2012 | 09:39 PM
Gotcha, I've looked it up. Seems like the majority of people get four-five inch bolts thread them into the assembly and knock it out with either an impact hammer or some sort of big maul. Off to the hardware store tomorrow!
Old Dec 28, 2012 | 05:45 AM
92 civic ex 4dr's Avatar
I don't know about you but i have a 97 accord and i don't have to remove the hub assy to put new studs in. Just remove the caliper and heat/debris shield and there is a notch cut out on the back of the spindle to put in the new studs. I haven't done it for a while so i can't tell you exactly how it's done but you can do it without removing the hub.
Posted from Honda-tech.com App for Android
Old Dec 28, 2012 | 10:09 AM
v4lu3s's Avatar
RTFM
i actually just replace all 4 studs on a hub while doing a 5 spd conversion yesterday.
i left the knuckle on the car, took the axle and caliper off and then loosened the 4 bolts that hold the hub in,put an impact socket on and hammered a little on each bolt and the hub popped out, then hammered the studs out, and put the new ones in. i have done them from the rear when it was jsut one before but it was a pain in the *** comapred to doing all 4 while it was all out.
Old Dec 28, 2012 | 06:53 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Posting this as a reference
http://www.youtube.com/watch?feature...v=UirzXEmnxVc#
go to 3:33
DaleW
Suspension & Brakes
10
Jul 20, 2011 05:09 AM
^XpLiCiTxX^
Oct 18, 2008 01:44 PM
rbizzell30
Mar 19, 2008 12:11 PM
RSD
Feb 17, 2006 01:05 PM
Archie_G
Nov 18, 2003 01:39 PM
