Help with HKS SSQ BOV?
Old Oct 19, 2002 | 08:02 PM
wzcb08's Avatar
Default Help with HKS SSQ BOV?
I have a turbo charged b18b hatch boosting 9psi and it has been without any problems for 2 months. Today I was driving around and I floored it in second gear, all of a sudden I hear a big phssssss noise and I thought I blew a tire or something. I checked my tires and everything was fine. I got back into my car and started to excelerate on freeway and I noticed that the blow off valve was not sounding off anymore and I noticed that when I floored it I was only boosting about 4psi (normal is 9psi). Later I discovered that the adjustment screw and nut to the BOV is missing!!!! I tried placing another screw in its place but it is still not boosting anywhere past 5 psi and it sounds like it is leaking. I checked my intercooler piping and it all looks good. Can anyome recommend where I can get replacement parts? I tried HKS but I didn't see the parts there. Any help would be great.
Old Oct 19, 2002 | 08:25 PM
MachAF's Avatar
Default Re: Help with HKS SSQ BOV? (wzcb08)
Have you checked your wastgate? it could be leaking also.
Just a thought
Old Oct 19, 2002 | 08:30 PM
wzcb08's Avatar
Default Re: Help with HKS SSQ BOV? (machaf)
I thought it was the wastegate at first but everything looks good. I am also running really rich too so I know it must be a vaccum leak of some sort possibly. I can feel it build up boost to about 4psi and then it looses it really quick. So it can build boost but does not hold it.
Old Oct 19, 2002 | 11:45 PM
Etylorcen's Avatar
Charge pipe might of blown off or the rubber cuppler.
Old Oct 20, 2002 | 12:52 AM
boostedsol's Avatar
Default Re: Help with HKS SSQ BOV? (Etylorcen)
if it dosen't hold boost then it may be a leak in the piping.....but u say that the bolt that goes with the ssbov is missing then there is your problem. u need to replace it asap. I have never heard of the ssbov bolt falling out before, but u need 2 fix that. peas.
Old Oct 20, 2002 | 03:56 PM
wzcb08's Avatar
Default Re: Help with HKS SSQ BOV? (boostedsol)
Do you happen to know where I can find a replacement bolt? Or if someone has one can you give me the measurements of that bolt.
teddy_dc2
Oct 6, 2005 07:24 PM
Scubster
Jan 27, 2005 08:33 PM
Blanket Jackson
Nov 28, 2004 12:18 PM
DOHCarp
May 31, 2003 09:17 AM
sleepy
Jul 4, 2002 04:54 PM
