Re-wiring b16 battery from the front to the back
Old Dec 26, 2012 | 08:56 PM
JustEFit's Avatar
Default Re-wiring b16 battery from the front to the back
hey guys ive seen ppl wire up their battery to the back to make their bay cleaner how is it done? Does anyone has pics how to do it??
Old Dec 26, 2012 | 10:51 PM
Canadian_EF's Avatar
Default Re: Re-wiring b16 battery from the front to the back
not hard, just bolt a battery box into your trunk and run 0 gauge wire from there to the under hood fuse box. Make sure to use a big fuse, 200 amp is what I'm running.
Make sure you either use a sealed battery or a sealed/ vented battery box.
Don't relocate the fuse box to the trunk.
Old Dec 27, 2012 | 08:01 PM
Slen17's Avatar
ya make sure you run 0 guage. I ran 2 guage and it couldn't run enough current to start the car. Just as a heads up. Also Canadian EF is right, don't put your fuse box in the back, but you want to run your 200 Amp etc fuse next to the battery(within 3 feet). that way your not burnin up your whole power line.
DialedLife
Mar 31, 2019 12:07 PM
84Riceeater
Oct 27, 2017 11:43 AM
delsolo95
21
Jan 6, 2012 09:11 AM
4g4dcruisin
19
Jun 30, 2010 10:31 AM
lancerkid06
24
Feb 16, 2009 05:08 PM
