What type of metal is a 1991 integra 5 speed transmission case?
Old Dec 26, 2012 | 05:09 PM
devinp52's Avatar
Default What type of metal is a 1991 integra 5 speed transmission case?
Basically I have a 1994 civic with an B18a1 ls swap and a 5speed cable ls tranny. When i went to take off in first gear today my e-brake cable was froze and my car would not move.
So i tried to take off a bit harder to see if it would break free, when i did this my cheap swap mounts allowed my engine to move enough to break the shift linkage stabilizer arm off of the trans, when this happened it took about a 1 inch size piece of my trans off.
I need to know if the trans case is aluminum or pot metal?
if it is aluminum would i be able to tig weld it or should i just find a new trans?
sorry this is so long.
from what i have found it is aluminum but i cant find much
Old Dec 26, 2012 | 07:52 PM
el crapitan's Avatar
Default Re: What type of metal is a 1991 integra 5 speed transmission case?
aluminum. it can be tig'd.
Old Dec 27, 2012 | 04:40 AM
jazzRS's Avatar
this is pretty easy to figure out, if a magnet sticks, its steel, if it doesnt, its aluminum. although we all know its aluminum, just a trick for future reference
Old Dec 27, 2012 | 05:31 AM
fcm's Avatar
fcm
Old Fart
It can be welded, "tigged"...
94
Old Jan 1, 2013 | 10:47 AM
devinp52's Avatar
ok thanks guys i am going to tig it tommarrow. any advice on preheating and such? i dont want to mess up my tranny.
Im replacing my mounts and obviously trans fluid.
i have an extra cylinder of argon and was wondering if i should try and fill the trans with argon to improve weld. this may be stupid and impractical tho
Old Jan 1, 2013 | 11:23 AM
fcm's Avatar
fcm
Old Fart
I disassembled mine befor welding, but did nothing else. 94
2x0
Transmission & Drivetrain
18
Jul 3, 2017 11:30 AM
rstchris
Jan 29, 2012 04:09 PM
97EXCivicCP
Mar 11, 2006 08:10 AM
