Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic front end shaking on take off
Old Dec 26, 2012 | 05:08 PM
harrycat's Avatar
Icon2 01 Civic front end shaking on take off
Just had a new clutch kit installed and flywheel resurfaced and the car is still shaking in the front end when I take off? is this some kind of internal transmission issue? its a 5 speed manual. also replaced all 4 motor mounts and compliance bushings (front of lower control arm) the rears were fine. im thinking its the bearings the cv axles slide into???
Old Dec 26, 2012 | 07:11 PM
toyomatt84's Avatar
Sanji
Default Re: 01 Civic front end shaking on take off
When you release the clutch pedal, how quickly do you do it? Manual cars will buck a bit, if you just dump the clutch.
Old Dec 26, 2012 | 08:17 PM
harrycat's Avatar
releasing it quickly but not just dropping it. the slower I release it the more it shakes. if I gradually let it out I can keep it in the zone where it begins to shake the whole front end. bur I try to get through that zone quickly. I am ok with it but my wife does not like the shaking. it is abnormal. I dont think a guy should have to rev it up to keep it from shaking like it does,but that does seem to help. when I replaced the clutch last week the old one was discolored (the springs in it and pressure plate) purple from the heat.
Old Dec 26, 2012 | 08:57 PM
EternalHour's Avatar
Is your clutch fluid reservoir staying full? When you release the clutch pedal, when does the clutch begin to engage?
Old Dec 27, 2012 | 04:48 PM
harrycat's Avatar
fluid level is full and fluid is clean. it begins to engage about 1/4 of the way up (THE PEDAL) Could a misfire in a cylinder cause this? it even shakes when I jack up the tire off the ground and let out the clutch with no load on it?? both sides
Old Dec 27, 2012 | 07:22 PM
Yes, it could, I have a misfire and my front end shakes a little too.
Old Dec 28, 2012 | 01:42 PM
EM2abe's Avatar
did you break your clutch in correctly? how many miles on the new clutch and how many RPMs to you go until you shift gears? also, what kind of clutch did you have installed?
Old Dec 28, 2012 | 10:06 PM
jdmeg6118's Avatar
I have the same problem, replaced CV shafts with no results.
Old Dec 28, 2012 | 11:36 PM
k20whitevic's Avatar
Since no one has asked, which clutch did you have installed?
Old Dec 29, 2012 | 05:47 PM
harrycat's Avatar
exedy oem replacement
im thinking its the bearings in the tranny where the cvs plug into??
Anythingbtcivic
15
Jan 22, 2013 03:34 PM
EKris
Honda S2000
Jan 20, 2010 07:54 PM
89civicsiowner
15
May 22, 2009 01:24 PM
97accordex
Jul 23, 2002 05:24 PM
