Gargae cleanout k series dc5 turbo etc
Im cleaning out my garage an thought I should sell some parts to find my new project.
I have rsx type s front and rear brake set up control arms and knuckles all complete. 350 OBO.
Also have my type s engine had 57k when I spun a bearing no.3 to be exact. Missing header, water pump n vtec solenoid.
Also have the matching transmission( currently at my uncles shop. Someone needed it but hasn't paid for it) I I have a serious buyer I can drive out to pick it up.
Have a b series log style manifold. ( was told it was a hks one but see no hks stamping.) looks the greddy one. -SOLD
Have some skunkworks(skunk2) coilovers lost some of the collars so would be used mostly for the spring only. -PENDING
Type r lower control arms. Only have one strut the other one walked away.
Type r valve springs
Also have type s door panels
Type s center console with shift boot
Type s radio bezel with hazard switch
Dc NRG slim hub n quick release-SOLD
Lucas 440 or 450 injectors new never used.
Obd2a p2p ecu
Skunk 2 70mm TB used only on mock up motor.
Ill take another look and add more when I'm home.
Obd2a p2p ecu
Gsr transmission came out of my sister car guy that replaced her clutch put a oversized bolt n broke the casing on it where the tbracket mounts it came from her db8 vin still intact
Have some skunkworks(skunk2) coilovers lost some of the collars so would be used mostly for the spring only. -SOLD
Obd2a p2p ecu
B16 transmission no grinds no pop outs. Smooth.
DB8 transmission needs a bolt extracted from casing where t bracket mounts n needs a helicoil on the other bolt.
Obd2a p2p ecu
