Da turbo question
Old Dec 26, 2012 | 10:07 AM
Bullet808's Avatar
Default Da turbo question
car: 93 integra auto to 5spd converted
Specs: b20 block with a b18a1 auto head. 450cc Injectors DSM. 255 fuel pump
My question is it has a stock auto ecu and car is running rich, rough idle untill warm and I was wondering which ecu/tune to use
Old Dec 28, 2012 | 01:06 AM
kodylive's Avatar
Default Re: Da turbo question
obd1 or obd2?
Old Jan 4, 2013 | 01:48 PM
Bullet808's Avatar
Obd1
Old Jan 4, 2013 | 05:02 PM
sirtef9's Avatar
obd1 tune it to 5 speed capabilities, auto will hold you back alot.
Old Jan 8, 2013 | 11:58 AM
Bullet808's Avatar
If I get a stock p28 will I notice any difference? Or would it still run the same ...
Old Jan 8, 2013 | 03:44 PM
bigislandc2's Avatar
are you using stock ecu to run dsm injector? a tune will solve alot of your issue. find a good tunner to tune!!
Old Jan 8, 2013 | 10:49 PM
B20ztek's Avatar
The p28 is made to run the D16z6, which is sohc.
You have a 2.0, which is DOHC. Will not work without being chipped. If I were you, look up phearable or Xenecron tuning, they both have a website. Go there, and read.
You will need to socket your ecu, and get a basemap for a b20. Also, no need to have 450cc injectors on an otherwise stock setup.
Old Jan 9, 2013 | 07:08 PM
Bullet808's Avatar
Sorry forgot to add that it is turbo and a non v
Old Jan 9, 2013 | 08:22 PM
what island you from??
Old Jan 10, 2013 | 07:18 AM
Bullet808's Avatar
Oahu
FeedBack159
Honda CR-V & Element
Jan 17, 2013 12:56 PM
TruVa
Nov 14, 2011 06:14 AM
BanEL
Jan 30, 2005 07:43 PM
Toda Built
Jan 15, 2004 05:52 AM
ZC_Power
Apr 13, 2003 10:58 PM
