Car shut off while driving? (nyc area)
(The car is about 2minutes off the 95 near Harrison and Rye NY just south of Port Chester and CT)
So tonight I was leaving my grandma's to go back home and when I pulled off the exit to pick up my friend the car lost all power to the gas pedal and went quiet. As I was still rolling I pop-started it which worked for half a second and then nothing. Checked all fluids and whatnot because it had been a road trip and now it turns over fine but doesn't sound like the fuel is igniting?
Tried started fluid which did nothing and couldn't get it into a shop or anywhere with light and tools because well today is christmas... I checked connections on the distributor/starter and battery, but they all seemed connected although slightly corroded. Is there something I am blatantly missing which I could try in the morning before having to get it towed someplace and pay money that honestly I dont have.
any help this evening would be amazingly appreciated!
Check for 12v at the blk/ylw wire to the distributor.if there is 12v,the distributor internals are the problem.if no 12v,you're looking at ignition switch or main relay.
DoWnfall
Dec 25, 2012 04:03 PM
rice a roni
19
Mar 18, 2005 09:25 AM
rasta420
25
Jun 11, 2004 06:36 AM
