Throttlebody question
Old Dec 25, 2012 | 03:19 PM
The_Head's Avatar
Default Throttlebody question
I have a GE intake manifold on my engine (H22A, 2414 cc's, 13.5:1 compression, etc). We measured the opening on the manifold, it's about 74 mm. The throttle body I have now is 65 mm. I was told I needed a larger throttle body or the throttle body gasket will get sucked into the engine due to the difference in the hole size of the manifold vs the size of the throttle body.
I think he's (the builder) is full of it and is just trying to sell me a larger throttle body. He wants me to get a 70 mm throttle body. I think that would be overkill.
If you do think I should get a better throttle body, what brand would you recommend these days? I've not followed the "scene" for a long time and no longer keep track of what's good and what's not.
Thanks.
Old Dec 25, 2012 | 06:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Throttlebody question
Your manifold is overkill.
Old Dec 25, 2012 | 06:30 PM
doood's Avatar
been there done that
why would you use a huge manifold like that then choke it with a dinky throttle body?
Old Dec 25, 2012 | 08:10 PM
mechanix619's Avatar
Ditch the GE manifold. Unless you're making over 700WHP.(that's a ballpark number) its overkill.
Old Dec 26, 2012 | 06:18 PM
The_Head's Avatar
Its too late now. Its bought and paid for and on the motor. I should have gone with a rosko euro-r manifold, but I didn't.
With that said, I would appreciate an answer to my throttlebody questions.
Old Dec 26, 2012 | 08:39 PM
boostedshoebox's Avatar
Do a reverse gasket match. Place the gasket on intake and trim away excess gasket. Use a new blade to get a clean trim. As far as tb being too small or not or choking the mani I'm not sure of that.
Old Dec 27, 2012 | 02:26 AM
Urus's Avatar
i had a good MAP numbers with 70mm on b18
now my 64mm works good before 7500rpm on b16NA. and will be replaced with 67mm
builder not kidding
Old Dec 27, 2012 | 03:32 AM
The Grumpiest
You got an answer. The TB you want to use is too small. Poor planning sucks.
Old Dec 31, 2012 | 07:10 AM
The_Head's Avatar
Thanks to Urus and boostedshoe for your responses.
Gsrsi
Dec 4, 2011 03:04 AM
92egboost
Jul 15, 2008 05:18 PM
tegSB85
Nov 17, 2005 05:50 AM
Fink2iCe
Aug 20, 2004 10:50 AM
Phatch99
Jun 9, 2004 07:11 AM
