JDM Spec S1 Cable Tranny clutch pedal squeecking
for some reason my clutch pedal always squeeqes everytime i press on the clutch, what can i do to prevent this?
where the pedal pivots on the linkage under the dash, lube it up with wd-40, silicone lubricant spray, white grease spray, or just some wheel bearing grease. of course you would have to just take the pin out to do it correctly.
Mine does that too bruh, but I was just blaming it on my stage 1 clutch......I personally just have the radio up to where I can't hear it, but try some WD40 or maybe some all purpose grease.......I've been too lazy to try anything.
lets keep answering his question with the same answer i gave him after he posted the problem, smh!
problem solved, close thread before 20 more people say grease!
i tried replacing the cable and grease and the squeak is still there, i'ma try to replace the spring next. before i take the whole thing apart.
ok...didnt know a cable would squeek lol, maybe more of a stretching sound...good **** that you fixed the problem, antifreeze works also for future reference if it does it again...oil is thick and prob wont lube the cable all the way, and at least with antifreeze it can lube it from one end to the other.. ive used antifreeze on pto cables for tow truck trucks and other large trucks, but same principle for your clutch cable.
Black R
Nov 13, 2004 11:06 PM
