506T Audio Sensor Not triggering alarm?
Old Dec 24, 2012 | 03:52 PM
jc95148's Avatar
Default 506T Audio Sensor Not triggering alarm?
It flashes its red led every time the windows are hit but no alarm, I even hit the window repeatedly with my keys and still not triggering the alarm. I have put the sensitivity to the highest already and still not triggering. I even locked myself in my civic and shook my keys in front of the remote and did not trigger it, just red LED flashing. What is wrong with this? I have it hooked up to a Viper 5900 using the included harness where you plug the shock sensor also. I know its working because of the red LED but it is not triggering the alarm. Please help. Thanks!
Old Dec 24, 2012 | 05:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 506T Audio Sensor Not triggering alarm?
Were did you buy the alarm and sensor? If you ground the trigger input. Does the alarm go off?
Old Dec 25, 2012 | 09:54 AM
jc95148's Avatar
nothingbutsoftware.com
But how exactly do I ground that?
Old Dec 25, 2012 | 10:02 AM
jc95148's Avatar
also my shock sensor works
Old Dec 25, 2012 | 10:18 AM
Faulty sensor. Have you tested the sensor output and see if it throws out a ground signal.
Old Dec 25, 2012 | 10:29 AM
jc95148's Avatar
ok checked ground using a multimeter on the mux of the sensor and chassis and every time I made a sound it detected continuity
Old Dec 25, 2012 | 10:39 AM
jc95148's Avatar
but it is still not triggering the alarm? Only my shock sensor does.
Old Dec 25, 2012 | 10:52 AM
fcm's Avatar
fcm
Old Fart
Plug the glass sensor into Mux port without the shock sensor, does it trigger the alarm?
If not use a jumper lead to supply a ground to the blue lead of the glass sensor, with blue lead plugged into alarm. 94
Old Dec 29, 2012 | 11:01 AM
jc95148's Avatar
Sorry for the late reply, was on vacation. But I tried it today and No it does not trigger the alarm. Where do I find the jumper lead? Thanks!
Old Dec 29, 2012 | 12:19 PM
fcm's Avatar
fcm
Old Fart
If the 506T does not trigger the alarm when installed by itself, it is a good bet the sensor is bad. 94
~sp33~
Audio / Security / Video
Nov 5, 2009 02:15 PM
ROCsFinest
Jun 8, 2009 11:03 PM
chinoty
Sep 11, 2007 06:22 PM
chinoty
Apr 7, 2007 04:56 AM
Bangers
10
Apr 5, 2006 08:26 AM
