D-series oil pans interchangeable?
I did a search on this, but couldn't find my answer.
I noticed that I have a dent in my oil pan and I would like to change it. I would like to start hitting the junk yards to find a good condition OEM oil pan and i'll just buy the oil pan gasket brand new from the dealer.
My question is if all D-series motors share the same oil pan? It would be awesome if someone could shed some light on my question because it would make it 10x easier to find an oil pan if I could pull it from any D-series motor instead of having to get one exactly from a D15Z1.
Thanks in advance!
Thanks in advance!
Ok, so I was digging around a bit more and it turns out that the 92-95 Civics d-series motors share the same oil pan part number. But, the 1996-2000 have a different part numbers.
Can anyone confirm that the 1996-2000 civic d-series oil pans do not fit?
88-95 d15/16 will interchange with yours
96-00 d16y7/8 will interchange with each other but not exactly a bolt on affair for 88-95 due to different oil pickups and dipstick locations, but need to match gasket with the pan because they are different
