DIY stock intake piping upgrade :)
Most of you will think I'm a geek for looking into this but I'm all about $ per HP.I recently decided to see how much bigger a 94-01 integra's stock intake piping was than a stock 88-91 civic. These were the results.
INTEGRA 2.5/8" at the throttlebody
CIVIC 2.1/2" at the throttlebody
The integra has roughly 5% bigger inlet
INTEGRA 3.1/2" at the filter end
CIVIC 2.7/8" at the filter end
The integra has roughly 18% bigger outlet
So from my findings just by upgrading to a B series intake piping it would allow your motor roughly 15-20% more air flow.Hope this helps someone.The way I think about it is for $10 to Have a little upgrade like this might help a few people out there.Let me know what you guys think of my "findings" Matt
top intake piping is from the 94-01 integra,bottom piping is from a 88-91 civic.
Yes, I'm curious as well how you came to the conclusion you received a 15-20% increase in airflow.
Just because there is more area for flow doesn't mean that you actually gain power or usable power btw. Velocity and turbulence play a factor as well. If you look at the Integra pipe, there are two bends with one of the bends being pretty sharp. The civic pipe is relatively straight.
It's not even an experiment. Not even a cheap one.
All the info you've provided past the physical measurements of the piping is just you guessing with not a shred of data to back it up. The piping is bigger so it must flow more? So what? The end result of this "mod" is supposed to be what? To increase horsepower? Fuel economy? What? The dyno is the only place that you can get definitive answers with something like this and you didn't even use one.
So you're saying this was a useless mod?
And still not answered one question put to you.
something better would be maybe to replace the stock elbow with something more smooth and less turbulent like a silicone elbow. might give better response but that's it.
Charlie Moua
Sep 8, 2005 04:20 PM
