Type of Axles that's Mostly used on a b16a swap
Old Dec 23, 2012 | 07:42 PM
JustEFit's Avatar
Default Type of Axles that's Mostly used on a b16a swap
im looking to replace my axles, i bought the car with the swap already, and the previous owner bottomed out pretty bad so the passenger side axle is bent and it sounds like the wheel bearing is going. so what type of parts can i use to fix this problem properly?
Old Dec 24, 2012 | 01:01 AM
Redline130's Avatar
Default Re: Type of Axles that's Mostly used on a b16a swap
Depending on what transmission you have, odds are 90-93 Integra axles are what you need. As for the bearings, just get the bearings for whatever chassis you have, unless your using Integra hubs/spindles.
Old Dec 24, 2012 | 06:34 AM
gringo7718's Avatar
This should answer your questions: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/official-b-series-transmission-clutch-guide-2931549/
Old Dec 24, 2012 | 11:15 AM
JustEFit's Avatar
JDM spec s1 tranny
so do i use 90-93 Integra axles?
Old Dec 24, 2012 | 03:09 PM
gringo7718's Avatar
Passenger side will definitely use a 90-93 integra axle.
The divers side will depend on which intermediate shaft you have.
*Most S1 transmissions come with the intermediate shaft that works with 90-93 Integra axles, but if you want to be sure, check which intermediate shaft you have. (Crawl under the car and look up at the intermediate shaft mounting bracket where it bolts to the block. Compare the mounting brackets to this pic and then you will be 100% sure.)
top - Y1 intermediate shaft = custom length driver's axle
bottom - 90-93 integra intermediate shaft = 90-93 integra axles
Old Dec 29, 2012 | 04:13 PM
JustEFit's Avatar
ill jack up the car and check if i have a shaft like this
88 civic ef
Apr 19, 2006 03:01 PM
EF8-SiR
Dec 19, 2005 05:04 PM
ITR632
Apr 21, 2003 12:09 PM
XANDER-666
Oct 7, 2002 12:04 PM
JJ-Built
Jan 2, 2002 08:27 AM
