What rings should I go with for my JE pistons?
Old Oct 19, 2002 | 06:18 PM
CRXGSR's Avatar
Default What rings should I go with for my JE pistons?
I know this is not directly a FI question, but I know many of you are using these pistons with your FI motors (as I will am currently building one as well).
Anywayz, I received my 84mm CRV JE pistons. I went the cheap way, and didn't get JE pistons rings with them. I thought I could use stock OEM honda piston rings (as I have some hookups with honda guyz). Anywayz, when I tried to install them, the top piston ring doesn't fit!! The groove on on the JE piston is slightly smaller. But the other rings fit fine. Does anyone else have this same problem?? Does that mean that I have to go with aftermarket rings (JE I suppose)??
Here's a pic of what I'm talking about. It's #1 in the pic:
Old Oct 19, 2002 | 06:23 PM
tony1's Avatar
Default Re: What rings should I go with for my JE pistons? (CRXGSR)
Use the rings that come with the pistons, that you didn't buy. The honda ones are a different size, obviously. The rings that je uses are pretty good and will hold all the power you can throw at them.
Old Oct 19, 2002 | 10:25 PM
bigTom's Avatar
Default Re: What rings should I go with for my JE pistons? (tony1)
Old Oct 19, 2002 | 10:41 PM
dustin's Avatar
Default Re: What rings should I go with for my JE pistons? (ek9t)
Use JE rings.
Old Oct 20, 2002 | 03:56 AM
b18CT's Avatar
Default Re: What rings should I go with for my JE pistons? (dustin)
i have je piston whit oem honda ring ,fit perfectly, boosting 22 psi
ive eard that the new je piston are no more compatible whit oem honda ring!!!!???
maybe someone can clear this.
Old Oct 20, 2002 | 05:29 AM
SiR Kid's Avatar
New User
Default Re: What rings should I go with for my JE pistons? (REVTurbo)
I've read that JE sends out LOW tension rings with their pistons. Low tension meaning motor cycle style rings that allow for some blowby and smoking in a N/A engine. With FI this just causes all kinds of problems because of higher cylinder pressures, which is the issues I'm having now with my pistons and JE stocked rings.
They've JUST NOW released the normal tension rings for their piston, which I'll be upgrading to once I pull the head to have a valve job/seals done.
Anyone else ever hear about this problem?
Old Oct 20, 2002 | 06:48 AM
Farnsrocket's Avatar
Default Re: What rings should I go with for my JE pistons? (SiR Kid)
Nope.........I hope mine are normal rings.
Old Nov 4, 2002 | 05:14 PM
civicsitek GanGsTa's Avatar
Default Re: What rings should I go with for my JE pistons? (Farnsrocket)
Im actually having the same blowby problem with my h22. It has wiseco pistons and the rings that came with the pistons. What's up with the weak rings being supplied with aftermarket forged pistons? What rings are everyone running?
Old Nov 4, 2002 | 05:21 PM
CivicGSRTurbo's Avatar
Default Re: What rings should I go with for my JE pistons? (civicsitek)
crome moly total seal rings
Antony
Old Nov 4, 2002 | 05:27 PM
earl's Avatar
The rings should work fine. Was the block bored or just new pistons installed. If you didn't bore and hone, that's where the problem is.
Old Nov 4, 2002 | 05:47 PM
Ltech's Avatar
Default Re: What rings should I go with for my JE pistons? (earl)
Remember to gap those rings too.
thugsbryan
Engine Machining & Assembly
Apr 5, 2018 06:39 AM
b20vtech
May 10, 2007 06:23 PM
ssr_h22
Sep 6, 2004 09:21 AM
swlabhot
May 13, 2004 01:38 PM
