98 compression cylinder one
Old Dec 23, 2012 | 12:30 PM
JDMequalslife's Avatar
Default 98 compression cylinder one
so my car hasnt been running good, has over heated once just because i was going up a steep hill and that was months ago, but thought i could be the head gasket. so did the compression test, was only able to do one because the cheap autozone tester broke, but cylinder one came out as 98. My question is could a head gasket being cracked lower the compression that much? i was thinking piston rings but i friend said it could be, i do over rev sometimes. car has 128k on it the motor is a sohc non vtec zc
Old Dec 23, 2012 | 01:34 PM
98civdx's Avatar
Master Detailer
Default Re: 98 compression cylinder one
Get a different tester and do it again. If it broke after one, I wouldn't count on it being accurate.
bvillarreal
Aug 22, 2013 09:43 PM
rxbahamut
Oct 17, 2011 06:33 PM
Jibin
May 21, 2009 05:58 PM
gloryhog
Jan 14, 2004 06:20 PM
BlkStang
Jan 11, 2003 10:19 PM
