Swapping DC2 Dash Black
I recently bought and 1998 Integra dash for my 1994 ls, my plan was to convert the tan to black, the first thing I noticed after installing the the dash was the new wiring harness would not plug up. So I pulled the wiring harness off my original dash and my plan is to install it into the new one. My only problem is that I cannot remove the connectors that sit in the front of the ac unit that control the hazard lights and defroster, without tearing everything to **** like I did with my tan dash. Can someone help me figure this out, pictures would be awesome.
You have to pop out the hazard and defrost switch. There is a screw behind each switch. once you pop those out, just take the screws out and unplug everything. I did the same thing on my db8...no issues.
Take a flat head and pry it from the bottom lip of the hazard and defrost button but be careful don't put it on the lip of the button but the lip of the case! Wiggle it as your pulling it out!
B_Swapped93
Nov 19, 2013 03:34 AM
