Question about SplitFire Twincore V Charge 8.8mm plug wires
Old Dec 23, 2012 | 03:23 AM
9tailsfox's Avatar
Default Question about SplitFire Twincore V Charge 8.8mm plug wires
Hi, Does anyone here know what are those thick black rubber with wording SplitFire work for? Thank You
Old Dec 23, 2012 | 05:27 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: SplitFire Twincore V Charge 8.8mm
Garbage, stay with oem
Old Dec 23, 2012 | 05:59 AM
grumblemarc's Avatar
The Grumpiest
If I remember correctly those were resistors.
Please don't tell me you're thinking of buying that garbage. And used even.
Old Dec 23, 2012 | 11:34 AM
Hidenplanvew's Avatar
just get some NGK's
Old Dec 25, 2012 | 05:52 AM
9tailsfox's Avatar
Default Re: Question about SplitFire Twincore V Charge 8.8mm plug wires
Merry christmas And Happy New year...
Old Dec 25, 2012 | 05:54 AM
9tailsfox's Avatar
Resistor? What for?
I'm not buying... just wonder what are those things attach like something works there. Thanks
Old Dec 25, 2012 | 06:02 AM
The Grumpiest
HTF should I know? I didn't design them. Maybe you should research them more yourself. And apparently they are capacitors.
This was from someone's old FS ad.
Made in Japan(Discontinue Product)
8.8mm Thickness
● V chargers are used to code the voltage loss can reduce the extreme, ultra-low-resistance employing pure copper wire. In addition, a charity tin plated to prevent oxidation. In addition, from both inside and outside of the inner heat-resistant high-purity silicon, as well as excellent chemical resistance heat-resistant silicone outer diameter of 8.8mm was covered with jackets. These allow easy flow of electricity in the direction of the characteristics of trying to escape, and enhanced core primary constant voltage spark plug is going to be like.
● The heart of the main core of the input voltage to a compression Rectified instant high-performance capacitors, and a built-in electromagnetic NOIZUSAPURESSA curb. Were the latest electronic control model is also assured.
<SplitFire V-Charger Effect>
● achieve more torque and power UP!
● improve the starting performance
● idling stability
● further response UP
● reduce damage to the engine
● improve fuel economy
● dress effect
● radiation prevention
Blue color
For B16/ B18/ B20 & D-Series
Very new condition, tip-top condition
Power gain in just a second
For Street use & Track use
Old Dec 25, 2012 | 06:06 AM
EsotericImage's Avatar
Retired Moderator
All these companies with promises of more power just from a spark plug or wire is hilarious.
Those E3 plug commercials on TV make me lol everytime. "just replace your plugs for more power" yea right
Old Dec 25, 2012 | 11:25 AM
Actually youtube has some videos of companys that did independent tests of the E3 its actually pretty intresting
Would I buy them ...No
JPerkMr954
Jun 19, 2012 08:30 AM
Dontoh
Jul 26, 2011 04:50 PM
jsrusse11
10
Nov 7, 2005 05:20 PM
highrolla
Feb 2, 2004 12:01 PM
