Another stripped 14mm fuel line nut
Well, it looks like I stripped the nut on the bottom of the fuel filter.
I tried PB blaster and I let it soak in all night. I even tried vise grips but it just making it worse.
As you can see from the picture that I was able to move the bolt off by two threads. Is it safe to drive it to my mechanic? Or should I just have the car towed?
Thanks
Thanks
Look at it while a friend turns the key to ON(II). That'll get the fuel pump going, pressurizing the system. If you don't see any leaks, you'll be fine to drive to the mechanic.
Rocky's_CRX
Jan 9, 2006 04:01 PM
