92 civic b18 swap explain this
Old Dec 22, 2012 | 08:52 AM
Mrmopar's Avatar
Default 92 civic b18 swap explain this
so still got the car cutting out at high rpm sumtimes car barleys wants to idle and at about 5 grand the lights get brighter alt belt is tight so i decided to unplug it the green plug and it idles fine and that battery light dont come on in the dash?
Old Dec 24, 2012 | 05:44 AM
A L I A S's Avatar
Default Re: 92 civic b18 swap explain this
sounds rediculous, but check your grounds...ive seen this happen before and it turned out to be bad trans ground
Old Dec 24, 2012 | 06:21 AM
tmodelt's Avatar
^ Agreed. I have seen this same issue with a bad ground.
max9505672
Dec 29, 2017 07:42 AM
Heathrow
Mar 22, 2013 05:49 AM
Hardedge
May 17, 2009 06:14 PM
hiimtommy
Apr 12, 2009 02:41 PM
BubbleBoyB16
Nov 2, 2005 02:33 PM
