b16a loss of power/bogs down 1k-3krpm
Old Dec 21, 2012 | 06:58 PM
1989through2010's Avatar
Icon2 b16a loss of power/bogs down 1k-3krpm
I have a 1996 Honda Civic Dx with a B16A Engine and a P30 Ecu.
I have had this problem for about 6 plus months now. The problem is after starting the car and it warming up when we drive the car seems to lose power or in other words bog down like kind of choke or have some sort of problem some where in the fuel, air, spark process. This problem only occurs during 1100 Rpm and 3100 Rpm. The car used to run perfect, very strong very fun. Now it just is a frustrating experience, only after 3k Rpm is there the normal power upon acceleration. My girlfriend and I share the car and when she drives the problem is not noticed as much because she tries to be very easy with accelerating. When I drive though I can't help but to get frustrated if I depress the accelerator more than just a little my problem occurs, I try to drive it easy but i just want the car back to normal. Oh yeah and at one point we tried tirelessly to fix this issue and I switched the fuel filter out and put injector cleaner in. No luck other than the usual oil and oil filter change nothing has been done. I would like to get my hands on a Obd2 reader and see what that shows, we'll see. I do have money at this time and would like to see if any one could offer some good knowledge about this. Thank you. Also i have read quite a bit about others problems exactly like mine and similar and I always read up until the thread ends with no written solution or the thread is still current. :\
Old Dec 22, 2012 | 01:07 AM
Default Re: b16a loss of power/bogs down 1k-3krpm
I will log on and check this out everyday this week. Just giving a heads up so if any one has any suggestions or some words they wanna drop dont hesitate. I am hoping to catch the eye of someone who has had a problem like this and found a solution.
Old Dec 22, 2012 | 02:24 AM
grumblemarc's Avatar
The Grumpiest
Do a full tuneup. Check mechanical/ignition timing.
Old Dec 23, 2012 | 11:27 AM
95*civic-hatch's Avatar
its only from 1100 -3100 rpm, after that is it ok or what
Posted from Honda-tech.com App for Android
Old Dec 23, 2012 | 11:47 AM
alswizzo's Avatar
As far as hooking up a obd2 reader autozone will do it for free.
Old Dec 23, 2012 | 12:54 PM
hybridmiklo's Avatar
if you are using a p30 ecu, the obd2 scanner isnt going to read jack.
njw202
Sep 4, 2011 02:47 PM
DJLikwid
Jul 28, 2010 06:38 AM
x1208x
Jul 19, 2009 08:10 PM
Triv
Jun 3, 2004 07:24 AM
90SIhybrid
Jun 22, 2002 12:43 PM
