Honda S2000 Honda S2000
CEL po300 and p2647...anyone had this before??
Old Dec 21, 2012 | 02:47 PM
ahtublao's Avatar
Default CEL po300 and p2647...anyone had this before??
trying to help my brother in law out here so im reaching out to my honda-tech master mechanics. lol. but yeah, he was driving around 45mph on the road and then the cel popped up. he started to feel the car lag and started to feel loss in power like it was misfing. He went to honda and got it diagnosed, they said that the code was p0300 (misfire), cleared the codes and test drove and cel p0300 came back on. MAP is at 1.12 and 1.22 at times. Performed leakdown test and found #2 and #3 20% Leakdown. Recommend removing cylinder head for inspection by machine shop. Customer approved removing head. Upon removing valve cover, tech found hard finish worn off camshaft lobes. They performed a valve adjustment and then called my bnl. At this moment my brother in law called me to go with him to honda to check it out and yeah the camshafts were pretty worn, probably from lack of valve adjustments. Then Honda recommended that he change out the motor which will cost about $4k-$6k which my bnl didn't have. So we told honda that we'll get a second opinion from somewhere else. We brought it home and i pulled the code again and it showed p2647-a rocker arm actuator control system stuck on (bank 1). that was the only code that showed and nothing saved?
So here we are, getting ready to take the head off but we want to make sure its the head again because its not misfiring,idles fine now after the valve adjustment. But i just dont know how to fix this p2647 code is. anyone who knows please shine some light and thank you in advance.
Old Dec 21, 2012 | 11:11 PM
Boots's Avatar
Default Re: CEL po300 and p2647...anyone had this before??
go to s2ki.com...look for a guy named billman250...he'll know exactly what you should do
Old Dec 22, 2012 | 02:17 AM
ahtublao's Avatar
thanks for the reply. did a comp test today and it came back 235 on 3 cylinders but the 4th cylinder had 180. DAMN! We're half way to getting the head off already and going back at it tomorrow. i'll update once we get the head off and to the machine shop for inspection.
Old Dec 22, 2012 | 02:21 AM
ahtublao's Avatar
but does anyone know where i can get some oem parts for cheap online? i need a head gasket for sure right now and just in case i need any of these: valves, retainers, springs, etc.....oh and cam shafts. t.i.a.
Old Dec 22, 2012 | 03:00 AM
lazlong's Avatar
Google "Honda OEM parts". There are several good online dealers. I usually use this one: http://www.hondapartscheap.com/index.php?p=home
Old Dec 24, 2012 | 04:56 PM
GhettoNinja06's Avatar
For parts either go to the parts site that Lazlong posted or my fav, http://www.hondaautomotiveparts.com/ Sounds like a terrible situation man, hope your bro get's his car running soon. I've already been waiting a month for mine
Old Jan 3, 2013 | 03:56 AM
ahtublao's Avatar
hey anyone know what i can do? when i took off the head, i scratched up the top of the block pretty good. (where the head gasket is supposed to go) possible that i can sand it down??if so, what should i use......
Old Jan 3, 2013 | 11:11 AM
Black S2K's Avatar
how did u "scratch" it up?
Old Jan 3, 2013 | 03:39 PM
ahtublao's Avatar
i sanded it down a little bit so you can't really see it anymore but will this be fine or would sanding down the whole top of block be better?
Old Jan 3, 2013 | 04:27 PM
Boots's Avatar
and this is why people who dont know what theyre doing shouldnt be tearing apart engines...its probably going to have to go to a machine shop now and hopefully it can be salvaged and you didnt do any permenant damage
Old Jan 3, 2013 | 05:45 PM
lazlong's Avatar
Originally Posted by Boots
X2.
You have something like .008 inches of play with that surface before it's out of spec. That's too small a measurement to do by eye or hand.
Take it to the machine shop to be surfaced properly.
Old Jan 3, 2013 | 11:45 PM
ahtublao's Avatar
thanks for letting me know, its getting pulled out and straight to the shop. lesson learned. i guess the only way to know is from mistakes. sheez i am human.
Old Jan 4, 2013 | 04:07 AM
Boots's Avatar
i understand that, but this is not the engine to be "learning" on...measurements on everything on this engine are very, very precise and it doesnt take much to **** them up
Old Jan 30, 2013 | 12:16 AM
ahtublao's Avatar
just an update. i got everything installed and its running hella good now. no more cels, running smooth and quiet as it can be.
EnjoyTheRideDC2
Jan 29, 2007 04:39 AM
EnjoyTheRideDC2
Jan 26, 2007 12:32 PM
blaze the chemi
Dec 8, 2006 04:08 PM
HiGH PSi
Acura TL, RL & ZDX
Dec 21, 2004 11:41 PM
