FS: Built 9:1 B16A Shortblock Complete
Toby Cook
Chambersburg, PA
Text @ 717-491-4891 for the fastest response
Selling a complete, built B16A shortblock that has less than 5,000 miles since the time of the build. Here are the details:
Stock-sleeve / stock-bore B16A block
B17 crank
Eagle rods
Custom JE pistons w/ wrist-pins moved up slightly on the skirt (9:1)
ARP hardware / head studs
Nice OEM oil pan tapped w/ a 10AN bung for oil return
Factory black box hole capped w/ full-race plug
Oil and water-pump were new at the time of the build
Clutch / flywheel + alternator not included with the sale. This is a VERY healthy shortblock, and it is otherwise good to go. I ran this motor in my eg hatch that recently made 515whp on 93 octane and 20lbs, which is very impressive for a stock-bore/stock-sleeve B16 setup. There are several people that can vouch for how solid this motor is.
Price is $900 firm and picked-up. Please contact me at the number above.
Thank you
Pic from the setup:
Chambersburg, PA
B17 crank
Eagle rods
Thank you
Pic from the setup:
The B17 crank in combination with the modified JEs increase the displacement slightly. So, it is essentially stroked and would probably cc around a 1.7 or 1.8 as opposed to a 1.6.
Thanks
Thanks
SilverStreak02
May 19, 2009 06:25 PM
