Can't find Y7 head what else will work ?
Old Dec 20, 2012 | 05:46 AM
B_Swapped93's Avatar
Icon2 Can't find Y7 head what else will work ?
My valves are warped on my current y7 head(took it off to confirm) i can't find a y7 head anywhere !. so im wondering if a vtec head(z6/y8/15b) would work WITHOUT hooking up the vtec solinoid ? this car is my dd and winter is coming so im under the gun to get it fixed.
TIA
Old Dec 20, 2012 | 06:03 AM
kyden's Avatar
Default Re: Can't find Y7 head what else will work ?
if you can find a y8 head, i suppose it would work.
try this site: http://car-part.com/
Old Dec 20, 2012 | 10:23 AM
92lxsleeper's Avatar
why not just replace the valves? you can also use a y8 head and do a mini me, or swap the y7 head internals into the y8 since they are the same casting.
Old Dec 20, 2012 | 05:34 PM
i don't know how to replace valves or move internals from head to head so would have to pay someone to.
Old Dec 20, 2012 | 06:19 PM
jbpnoman's Avatar
Or get a valve spring compressor and a factory service manual and do it yourself. It's really not that hard. In fact, as far as actual motor work goes, it's probably the easiest thing to do.
pnwjdm
27
Feb 17, 2014 01:31 PM
Civic98KH
May 16, 2007 09:16 AM
tdizz07
Mar 9, 2007 10:04 AM
eK9aT10pSi
May 30, 2005 07:47 PM
