Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Back again! Now Clutch is slipping.
Old Dec 19, 2012 | 06:17 PM
pearljamming's Avatar
Default Back again! Now Clutch is slipping.
So a month ago I replaced lower control arm bushings, now my clutch is slipping and when I downshift while slowing down, the transmission starts to emit a humming/winding noise.
The humming, I'm assuming, is coming from the throwout bearing, so I got the whole clutch kit. The clutch kit comes with the standard stuff:
-Pressure Plate
-Clutch
-Clutch Bearing
-Pilot Bearing
-Adjustment tool (Didn't come in the box, so I will have to hit up Autozone again tomorrow)
Basically my Haynes manual molded because the trunk seal was leaking water. So I want to know if I can get a manual for my car somewhere online for free. I'm trying to save money, hence why I'm doing this pain in the *** job myself.
Any information will help! Thanks.
Edit: 2002 Honda Civic Ex 1.7 SOHC (D17a2). I forgot to add this, thought it would help.
Old Dec 22, 2012 | 11:56 PM
It Wasn't Me's Avatar
Default Re: Back again! Now Clutch is slipping.
It's not the "throwout bearing" making that noise, but it sounds like you needed a clutch kit anyway.
You're going to have to open the transmission for an inspection of its internal components.
Edit: Does it make these noises during acceleration too? /edit
Just curious.. Does the noise go away when you press the clutch pedal to the floor, then come back after you let the clutch pedal back up? And had you been hearing a "hissing" noise prior to all of this happening? What about any "rattling" or "clicking" noises?
maxboost94
Sep 20, 2007 07:40 PM
TOAB
May 21, 2007 04:31 PM
rs
Oct 5, 2005 10:23 AM
SIKING
Oct 12, 2003 05:29 PM
