4th gen Prelude backfire, no start?
Old Dec 19, 2012 | 10:49 AM
aretwokay's Avatar
Default 4th gen Prelude backfire, no start?
I recently did a full timing job on my 93 Lude (F22a6 block/H23A1 head).
Replaced all belts, tensioners, seals, water pump, etc.
He was running beautifully for the last couple months, no problems at all! Then one day, at the end of an hour long drive, I ran into some trouble. Going about 60-65 down the highway, my car starts jerking around really hard. Lots of shuddering, lots of shaking, lots of backfire, no power at all. I put in in neutral and started coasting, and it immediately killed the car. When I put it back into gear, it jerked the engine on and kept running like ****. At a standstill, I get crank, but doesn't turn over. Tons of backfire while trying to start. I don't even know where to start. All the backfire sounds like timing to me, but I just did the timing? Any ideas?
Old Dec 19, 2012 | 11:29 AM
98vtec's Avatar
moderator emeritus
Default Re: 4th gen Prelude backfire, no start?
so check your mechanical timing.
Old Dec 19, 2012 | 11:39 AM
Mykizism's Avatar
yeah check to see if the timing belt didnt jump teeth.. the tensioner mave have failed or was never correctly set.
Old Dec 19, 2012 | 08:02 PM
AMR-MikE's Avatar
Also check your tensioner
thekeysarebroke
15
Oct 1, 2012 05:35 AM
[713]
May 14, 2012 03:23 PM
boarding2008
Jan 25, 2009 02:06 PM
turbols99
Apr 1, 2007 10:03 AM
pos_cd5
Jul 24, 2006 12:26 AM
