88 civic starts then dies
Old Dec 19, 2012 | 08:35 AM
justin-95si's Avatar
Default 88 civic starts then dies
I have a 88 hatch with a mpfi swap the last week or so my car will start for bout 1-2 sec then sputter out and die. If I rev it up rite as it starts it will run fine I usaly have to try a few times to get. It to actuly stay on. Any ideas iv cheched all my vacumelines like 5 times and checked all my electrica connections
Old Dec 19, 2012 | 09:03 AM
4g4dcruisin's Avatar
Default Re: 88 civic starts them dies
Fuel delivery problem it sounds like, or maybe your TB is stuck closed.
Old Dec 19, 2012 | 09:47 AM
I can hear the fuel pump kicking on I'm kinda thinking maby fuel filter but idk ill prob justt change both and see what happens
Old Dec 19, 2012 | 10:04 AM
JuicedUpRice's Avatar
You should hook up a fuel pressure gauge and see if the pressure dies out when the car does.if t does,this will tell you the fuel pump is bad or weak.
Could also possibly be an injector drizzling fuel instead of misting it out.pop them out and see if the fuel comes out of them as it should.
I would also keep the ignition switch in mind.if the start contact is bad on it,it would possibly start and then die out as soon as it runs
Old Dec 19, 2012 | 05:31 PM
Former User's Avatar
Default Re: 88 civic starts then dies
Is this a low idle problem?
Any CEL codes?
Old Dec 20, 2012 | 12:26 PM
Ya I think its 1 of the sensors cuz fuel pressure checked out fine and it runs normal once I get it to stay running. It does tro a cel once in awhile but it only stays on for like 2sec then clears its self so I don't have time to see what its for
Old Dec 20, 2012 | 12:30 PM
Have you cleaned the IACV?
Old Dec 20, 2012 | 02:07 PM
No I have not cleaned it yet I'm doing that first thing in the morning tho
Old Dec 20, 2012 | 02:17 PM
maineef's Avatar
map sensor mine if it comes unplugged will either die or run at like 150 rpms
fallingxlove
15
May 31, 2009 12:19 PM
Pr0ject93hb
Feb 25, 2007 08:34 AM
ef8 h0!
Oct 3, 2005 05:32 PM
onesikcivic
Sep 8, 2005 09:46 PM
hair_rice
Jul 5, 2004 07:37 PM
