intake manifold for mpfi swap
Old Dec 18, 2012 | 04:38 PM
cgross's Avatar
Icon2 intake manifold for mpfi swap
OK I'm trying to do a mpfi swap on my stock d15b2 an was wondering do I have to get the intake off an si or can I get it off of a (94 93 dx civic)ex..
Old Dec 18, 2012 | 04:58 PM
goldhatch94's Avatar
Default Re: intake manifold for mpfi swap
you can run any intake manifold you want. d16y8 d16z6 d15b crx SI or crxh HF.
only thing is if you have not converted the car to OBD1 and you stil want to run your OBD0 injectors you will have to run crx SI injector and resisiter box.
Old Dec 18, 2012 | 05:04 PM
cgross's Avatar
Great thanks for the help goldhatch
Old Dec 18, 2012 | 05:34 PM
cgross's Avatar
Im sorry but would I also need the dizzy I'm assuming I would
Old Dec 18, 2012 | 06:05 PM
it depends what you are runing if you are obd0 you will run a crx SI dizzy and ecu if you are obd1 you will run a d15b7 dizzy and ecu po6.
Old Dec 18, 2012 | 06:30 PM
cgross's Avatar
Well at the moment its just the stock dpfi I have been wanting to do the mpfi but wasn't exactly sure on how to do it Ive been reading up an read that to do it I will need the pm6 ecu throttle cable injector resistor box wiring harness the manifold throttle body an injectors but my real question is do I have to get all that off a si crx or hatch BC I was wondering can I use like an Ecu off a d16y8 an of course do the obd1 swap but also use like the dizzy off a crx an I'm sorry if this is really stupid but I can't find a car that has all of thae stuff I Ned to do the swap an thank u very much for your help already
Old Dec 18, 2012 | 06:38 PM
v4lu3s's Avatar
RTFM
then find it from multiple cars.
if you use a pm6 ecu you MUST use the si distributor.
if you use a p06 you MUST use the d15b7 distributor.
Old Dec 18, 2012 | 06:52 PM
cgross's Avatar
OK thank you very much hat sums it up for me an like I said I apologize for my stupidosity just wasn't positive an didn't know
204E-EF6
Dec 28, 2006 03:25 PM
rice is nice
May 12, 2004 09:21 PM
SPOON_EG6
Dec 9, 2002 04:03 PM
RicedREX
10
Dec 3, 2002 08:07 PM
OldGeezer
Mar 15, 2002 10:29 AM
