JDM cluster question.
Old Oct 19, 2002 | 03:28 PM
SMZ GSR's Avatar
Default JDM cluster question.
Hey guys, i drive a 98 GSR and just bought a JDM ITR cluster. I believe the cluster is from a 2000 or 2001 because it has the little key icon and only had 16k KM. Well my friend and i installed it today and both the temp and fuel gauges wouldn't work. the temp stayed at C and the fuel gauge went from me having a 1/4 of a tank to having a full tank. Then we tested the cruise control since the light on that wouldn't go off either. once cruise was engaged the Maint Req light came on.
My question is, could it be messed up because of the different year or is it busted? The guy i bought it from says he has a 94 and says it worked fine.
If it's because of the year, is there anyone in So Cal who would help me by trying it out on their 00/01 ITR. Thanks ahead of time.
Old Oct 19, 2002 | 04:46 PM
Dan GSR's Avatar
Default Re: JDM cluster question. (SMZ812)
its not busted......
I had similar problem with mine....the wiring is just different
Follow every wire lead...and firgure out what each wire goes to on your stock gauge cluster......then compare it to the new one you have.....you will have to switch some wires around.....
I was freaking out too when i first plugged mine in...but a little patience...and some wire splicing and you should be good.
Old Oct 20, 2002 | 02:21 PM
SMZ GSR's Avatar
Default Re: JDM cluster question. (Dan GSR)
Thanks for the advice but I tried out switching the green circuit piece as many other members suggested and now everything works perfect. My fuel went back down to where it should be, the temp gauge works and the cruise control light isn't stuck on. Thanks for your advice anyway. Now i don't have to search for a new one and bother the guy i bought this cluster from about returning it (which he was willing to accept)
Sifu
Aug 25, 2005 01:44 PM
SMZ GSR
May 10, 2004 02:57 AM
01DC-2
Apr 1, 2004 09:43 AM
P1mpSlap
Nov 30, 2002 11:57 PM
SMZ GSR
Oct 19, 2002 06:11 PM
