Fans not working 95 Prelude se
Old Dec 18, 2012 | 07:58 AM
civicguy167's Avatar
Default Fans not working 95 Prelude se
My radiator and ac fan dont work on there own on my 95 prelude se. When I jump the thermostat housing connector with paperclip they both kick right on. When I turn the ac on in car, it doesnt come on. I tried swapping engine compartment cooling fan relay and fuse. Since the ac doesnt kick on either would this be the fan timing box near the ecu? Or am I missing something else to check first.
Thanks
Old Dec 18, 2012 | 12:39 PM
tonypushard's Avatar
Default Re: Fans not working 95 Prelude se
Have you checked the CTS? it may not be sending proper info if any at all to the computer and therefore not turning on the fans. usually when you kick on your a/c both fans should run. just something you might check
Old Dec 18, 2012 | 03:10 PM
whats the cts? Im wondering if the fan system connected connected to the main relay at all? The main relay seems to be going bad.
Old Dec 18, 2012 | 06:54 PM
Coolant temp sensor duh. Yeah thats what I was thinking originally but since it doesnt come on with ac switch it seems that wouldn't be it. Unless if that sensor is bad and it completes the circuit maybe.
Old Dec 29, 2012 | 06:12 PM
lazerus0's Avatar
yeah i'd check your coolant temp sensor. if you can jump it and it kicks on, odds are that sensors toast.
Old Dec 31, 2012 | 07:16 AM
The cts controls the fan. It send info to pcm which turns on the fan. Just do a simple ohms test on cts when its cold and then again when its warm.there should be a difference and I well have to find specs of what its supposed to be. If u test the CT and its reading 0 ohms then chances good that its bad. Let me knowwhat your cure ends up being
ODbuilt
Apr 17, 2014 07:11 PM
Memnoch
Jul 11, 2008 07:47 PM
kknight
Jan 1, 2007 01:43 PM
crxdohczc
Feb 27, 2003 07:31 PM
HX_Guy
May 31, 2002 08:38 AM
