60a Fusible Link Blown
Old Dec 17, 2012 | 06:18 PM
CrxGrin's Avatar
Default 60a Fusible Link Blown
I am redoing my engine/dash harness on my 1990 crx si with a b18 swap. I wanted to test the dash to see if I wired it in correctly "lights etc" so I connected the battery and blew the 60a fusible link in the engine bay box. I have all the grounds on the dash harness on. Do I have to have the engine harness on as well and grounded before I test it?
Old Dec 17, 2012 | 06:26 PM
Former User's Avatar
Default Re: 60a Fusible Link Blown
Does it blow with the key off? If so, check the large alternator wire.
Old Dec 17, 2012 | 06:40 PM
CrxGrin's Avatar
I don't have any of the engine harness in, isnt the alt ground part of the engine harness?
Old Dec 17, 2012 | 06:45 PM
So only the battery is connected to the hood fuse box? Check for a short to ground in the hood fuse box. Does removal of all hood fuse box fuses except the 60A one prevent it from blowing?
Old Dec 17, 2012 | 06:47 PM
CrxGrin's Avatar
Havent checked that yet, ran out of fuses lol.. But I have a 4ga from battery to starter, then 8ga from batt to fuse panel. Batt is grounded and fuse panel is grounded to the thermo housing. No key in when it blows either just happens as soon as I put the neg cable on.
Old Dec 17, 2012 | 06:49 PM
What from the hood fuse box is grounded to the thermo housing?
Old Dec 17, 2012 | 06:50 PM
CrxGrin's Avatar
Brb grabbin a pic to show you. Kind of new to wiring.
Old Dec 17, 2012 | 06:56 PM
CrxGrin's Avatar
[IMG]Name:  ArXv9.jpg
Circled in yellow is grounded to thermo housing.
Old Dec 17, 2012 | 07:04 PM
That's the problem. You have the alternator wire grounded. Remove that wire until you are ready to hook up the alternator. Nothing from the hood fuse box should be directly grounded.
Old Dec 17, 2012 | 07:06 PM
CrxGrin's Avatar
Ah I misread the diagram =/ Thanks for the help I greatly appreciate it! The PO I got this from did a half a** job of a wire tuck. Had more electric tape then car it seemed lol. Tryin my hand at fixing it all.
freewealthana
Jun 22, 2017 11:07 PM
Gofast94
May 11, 2014 01:03 PM
xtpking3
May 6, 2014 05:05 AM
VanDuzer4
Honda Civic (2001 - 2005)
Nov 7, 2013 11:45 AM
Jmorin
Sep 24, 2003 09:55 AM
