D15B7 to d16z6 del sol
Old Dec 17, 2012 | 02:24 AM
mächtigen's Avatar
Default D15B7 to d16z6 del sol
I have a 93 del sol S, with the d15 in it and i picked up a d16z6 for next to nothing and i was wonder if the parts off the d15 like the manifold, fuel rail, those four pipes in the front of the engine will fit on the d16, also is it a quick swap to put the 16 in and is there any special parts i need to swap this? this is my first time playing with a car but i've wanted to try it for awhile. I'm sure theses are prolly stupids questions but i'd rather be safe then sorry later.
Old Dec 17, 2012 | 06:01 AM
B20DelSol's Avatar
Default Re: D15B7 to d16z6 del sol
Everything will swap right over for the most part. Those 4 pipes in the front are part of the exhaust manifold (if you don't already know). You may want check the Z6 for compression and do a leak down test on the cylinders to get an idea of what condition the engine is in.
From there, if everything seems okay, I recommend you replacing the water pump,timing belt, and tensioner, as well as a full tune up including plugs, wires, pcv valve, air filter and fuel filter. You may also want to replace the coolant hoses, clutch and possibly flywheel at this time as well.
Old Dec 17, 2012 | 11:03 AM
mächtigen's Avatar
Sweet thanks for the info, i'll have to post a pic when i get it done xD
Old Dec 21, 2012 | 01:11 PM
mächtigen's Avatar
So... Non vtec to vtec. should i buy a wireharness that has it or is it complicated to add it?
Old Dec 21, 2012 | 03:26 PM
strategy400's Avatar
Did you get the transmission? What type of transmission do you have?
Old Dec 21, 2012 | 06:32 PM
EFfin Sedan 91's Avatar
I recommend you do lots of reading and research before you attempt the swap. The more knowledge you have on the subject, the better off you'll be. Wiring for vtec is fairly simple- only 2 wires you have to run to the ecu (vtec solenoid, and pressure switch) and then a ground.
Here's a good write up on that:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
You'll also need a new ecu, the ecu for that engine would be an OBD1 p28.
Harnesses are fairly cheap on ebay too if you'd rather go that route.
Old Dec 22, 2012 | 11:31 AM
mächtigen's Avatar
Thank you
olish79
Jun 23, 2015 03:28 AM
Token_Tay
Sep 30, 2013 10:55 AM
Mason-RUS
Aug 15, 2007 12:29 AM
tambara
Jan 3, 2007 10:44 PM
Tad
Nov 12, 2003 01:12 AM
